Bobs RV7 Site
Date:  1-28-2008
Number of Hours:  4.00
Brief Description:  Oil cooler spacers and baffel fit
I made spacers for the oil cooler mounting bolts. Other RV owners have had problems with the oil cooler mounting flange cracking around the bolt holes, which may be due to insufficient support under the nuts. These spacers and washers will help prevent that.
I also riveted the insert into place where the left rear baffel makes a jog above the oil cooler. This now provides a smooth run for the baffel seals.
I also checked and adjusted all the baffels for the final fit. Some trimming and minor adjustments were made, and all edges were finished.
