Bobs RV7 Site
Date:  1-6-2007
Number of Hours:  6.00
Brief Description:  Forward Baffles
I made attachment brackets fo the forward baffles. I drilled them into position and did some mnore fitting of the baffles. The clearance between the cowl, baffles and flywheel is very tight and will require more attention. I also made some small fittings and riveted them to the underside of the right forward baffle floors. These will seal a small gap between the baffle floor and air filter, that is caused by the bend in the floor.
