Bobs RV7 Site
Date:  10-25-2009
Number of Hours:  4.60
Brief Description:  Cowling Air Inlet Work
The upper edges of the lower cowl at the inboard edge of the air inlet were not fitting very well against the lower cowl. There was not enough fiberglass structure in the area to do much sanding so I added some glass to the area. I also added some epoxy and microbaloon mixture to reshape the cowling lip. When dry I'll sand and shape this area for a better fit.
