I continued with the fitting of the lower cowl. The cowls overlap where they meet on the sides, and the cowl overhangs the fuselage at the rear. Fitting requires placing the cowl in position, holding it with tape, marking trim lines then removing and trimming. As the fit gets closer, the trimming is done by sanding the edges.
