Brief Description: Remade rear baffle fuel line access holes
When I attempted to reinstall the fuel lines to the fuel injection unit and purge valve, I discovered that the access holes through the left rear baffels were drilled wrong. I somehow reversed the position of the larger and smaller holes, and the hoses would have to cross to reach their correct connection. I didn't want to do this, so I made a doubler plate with the correct holes, and riveted it in place over the incorrect holes, then installed the hoses through rubber grommets.
