Bobs RV7 Site
Date:  2-15-2009
Number of Hours:  2.50
Brief Description:  Safety wire lower baffles
I was not happy with the way I had safety wired the firesleeve onto the throttle cable, so redid this. I then used safety wire to secure the bottom of the baffles where they curve around the edges of the cylinder fins. I covered the wire with flexible plastic tubing to prevent any chafing. I ran the end of the safety wire through washers to also protect the ends of the aluminum baffles.
