I did the final installation of the engine driven fuel pump overflow drain line. A plastic flexible line is secured with safety wire onto the fuel pump drain, then runs down to the lower firewall. A length of aluminum tubing was bent and attached to the lower engine mount, then directed through a hole drilled through the hinge and flange. I also wrapped this line in plastic tubing where it passes through the flange.
