Bobs RV7 Site
RV-7
Cowl to Fuselage hinge
I final drilled the hinges that attach the cowling to the fuselage. I also finished small aluminum blocks that will hold the lower cowl hinge pins in place and drilled and countersunk them. I then cleaned and primed the hinges.
RV-7 Home
2286
Administrative
Baffeling
Cowling
238
140
Empennage / Elevator
Empennage / HS
Empennage / Rudder
Empennage / VS
241
Instrument panel
163
Landing gear & brake
Systems
Upholstery
183
