I installed the brake line from the firewall fitting to the left main wheel brake. This involves using a flared fitting at the firewall then running the 1/4" tubing down the gear leg. It is attached with electrical tape, protected with plastic tubing where the brake line contacts the gear leg. At the bottom of the gear leg, the tubing is routed around the the leg and to the brake fitting. this loop allows ample play in the line for gear leg and brake movement.
