Bobs RV7 Site
RV-7
Installed engine mount
I mounted the engine mount to the fuselage. I had previously drilled the mounting holes into the frame. I did have to trim around the lower fuselage corners to allow clearance for the gear legs. I installed cotter pins into the attachment nuts.
RV-7 Home
2286
Administrative
Baffeling
Cowling
238
140
Empennage / Elevator
Empennage / HS
Empennage / Rudder
Empennage / VS
241
Instrument panel
163
Landing gear & brake
Systems
Upholstery
183
