Manufactured brackets for flanges that will direct defogging air onto the windscreen. Drilled, deburred, dimpled and primed these brackets. Made a template to locate where the defog air flange will be located beneath the forward upper skin. Located the position and drilled the upper skin for this access hole. Drilled and dimpled the skin.
