Bobs RV7 Site
RV-7
Mounted map lights
Installed map lights to the cockpit side panels. Drilled a mounting hole and installed nut plates. Repainted the panels. Installed insulation behind the side panels. Ran wiring from the lights to the dimmer circuit at the instrument panel.
RV-7 Home
2286
Administrative
Baffeling
Cowling
238
140
Empennage / Elevator
Empennage / HS
Empennage / Rudder
Empennage / VS
241
Instrument panel
163
Landing gear & brake
Systems
Upholstery
183
