Bobs RV7 Site
Date:  10-17-2004
Number of Hours:  4.00
Brief Description:  Avionics Soledoid and ground block
Installed the avionics relay. Drilled the firewall and manufactured a back plate support. Drilled, countersank and primed the backing plate. Riveted the plate and nut plates and mounted the abionics relay. Connected the battery relay to the avionics relay with AWG 2 wire. Drilled and mounted the firewall ground block and the smaller ground blocks supplied with the panel wiring.
