Bobs RV7 Site
RV-7
Installed Static Port
Drilled fuselage holes and installed the static ports. Routed the static lines from each port to a T connection to the line that will run to the instrument panel. Attached the lines to the airframe.
RV-7 Home
2286
Administrative
Baffeling
Cowling
238
140
Empennage / Elevator
Empennage / HS
Empennage / Rudder
Empennage / VS
241
Instrument panel
163
Landing gear & brake
Systems
Upholstery
183
