Brief Description: Drill, debur, dimple and prime rudder
Drilled, deburred and dimpled the rudder skin and stiffeners. Also drilled and dimpled the rudder spar. Primed the stiffeners, spar and interior of the rudder skin, using the same priming procedure as earlier used.
