Continued to work on wing ribs. Fisnished all .020 wings and began work on the 4 .040 ribs. Decided to make another form to accomodate the thicker rib. Well, it didn't work out and the rib ended up being about 1/8 inch undersized. Decided to use the pervious form but increased the radius for the bend. This worked out fine and the rib is exactly 5.5 inches high.
Will cut out another blank and finished ribs later.
