Continued fitting the CB Panel to the fuselage. This is going to be a NICE feature when it is done, should feel like a real airplane!
+ Layed out and drilled upper screw holes on panel. + Layed out and drilled CB Attach Angle screw holes. + Match-Drilled CB Attach Angle to Forward Fuselage Console
After I match-drilled the CB Panel to the forward fuse. console, I am not to happy with the fit. A new console was $6.00 so I have ordered a new one and will try to get a better fit the second time around!
