Not much more progress today. Made some progress, but I cannot figure out how to get my vent line into the gear tower and keep everything kink free. I am going to look into flexible tubing for this application... Activities today were:
+ Drilled second hold for fuel line through left gear tower. + Installed snap bushings in gear tower for fuel and fuel vent lines + Installed bulkhead fittings for fuel vent lines. + Generated a bending template with a coat hangar for vent lines + Bent fuel vent tubing.
QB builders forgot to enlarge the bottom hole.. .Not a problem!
Left bulkhead fitting installed for fuel vent line.
Fuel vent line bent to match template, now how to get it in the gear tower...???
