Installed Flap Motor. Had to detach the Aileron Mount Bracket from the bulhead in order to properly install the motor. Tested the motor wit ha 9V battery and everything worked fine! Installed Rudder Cable Supports in fuselage per the plans. Routed the Rudder Cable and snap bushings through the fuselage per the plans and secured the protective plastic tubing for the cable as directed in the plans.
