Began working on the rudder pedals. Removed ends of the attach brackets. I did this after researching the topic on VAF. Apparently the longer brackets only work on slow build fuselages where the holes can be properly drilled prior to assembly. I also measured and layed out the attach holes for the brackets, then drilled them.
