Began working on the "(in?)FAMEOUS TRIM TAB." Bent the tabs without incident, "Rivet Gun" method called for in the plans is NOT recommended for 3x or larger rivet guns. I was not very happy with the finish ir provided AT ALL and feel the gun was a little over powered. With the pressure turned ALL the way down, it still put creases in the fold line. I would reccomend some sort of lubricating agent to smooth the traveling of the rivet gun if you choose to finish the edge that way, I do not think it is necessary though.Match drilled the Trim horns to the skin and the false spar to the skin. Machine Countersunk the spar and trimmed the trim tab horns.Prepared all pats IAW Van's Construction Manaul. Scuffed, cleaned, and primed with Duplicolor Self Etching Primer.
