+ Finished Fabricating and installed line between Fuel Valve and Filter.
Fuel lines are DONE! As you can see in the pictures, I did add some shrink tubing to the line running from the valve to the filter. There is about 1/8 inch clearance between that line and the right fuel tank line, but I wanted to make extra sure there wouldn't be any chafing should the two lines contact due to vibration. I am still deciding if I want to use rigid or flexible tubing for the Vent Lines. I am leaning towards rigid right now, but am NOT looking forward to doing that work inside the gear towers!
