Fosters Web Site
Date:  9-17-2011
Number of Hours:  2.50
Manual Reference:  8-63
Brief Description:  Interior Painting #19 / Fuel System #3
Great Day! Horns stomped UCLA 49-20, and I got a good bit of work done on the project! Painting on Aft Fuselage Bulkheads turned out really well!
+ Final-Drilled Fuel Filter Bracket
+ Match Drilled Fuel Pump Bracket to Forward Fuselage Floor
+ Deburred and countersunk filter and pump brackets
+ Painted Aft Fuselage Bulkheads that will be in baggage area.
+ Primed and painted filter and pump brackets
+ Stripped and reprimed and repainted fuel selector valve brackets.
I want to get a good paint job onthe bulkheads that will be in the baggage area so that the will match the associated paint in the interior and lower section of the baggage compartment.
Fuel Pump Bracket match-drilled to forward fuselage floor.
Bulkheads painted, results were really good!
Brackets primed.
Brackets primed.
