Brief Description: Rudder Controls #3 / Trim Installation #3
Great Session today! Got a lot of work done and had an OUTSTANDING aerobatics flight this morning! Going to be getting everything up to date on here tonight and tomorrow as well! Tasks today were:
+ Primed other side of Aft Fuselage Bulkheads and associated parts. + Installed Brake Master Cylinders and Fittings on Rudder Pedals + Installed Rudder Pedals in fuselage and attached to Rudder Cables. OPS test OK. + Spiced wires on elevator trim servo so the could be extended. + Mounted Elevator Trim Servo on airplane and routed wires through empennage. + Trim Servo OPS check OK
Intent is to install a MOLEX connector for the trim servo so that it may easily be removed if necessary.
Rudder Pedals hooked up and working!
Trim Servo all put together, getting ready to splice wires.
Trim servo installed in elevator and hooked up to trim tab!
