Disassembled Control Assembly and installed in fuselage. Mounted rod end bearings to Forward and Aft Control Mounts. I also did some work on the fuselage stand as it was too tall. I removed the casters from the stand and everything is MUCH better. I have found that I do NOT move the fuselage hardly at all, so it is much better to have it lower than mobile!
