Re-measured and drilled #12 holes in WD827 & 828. Measured and match-drilled (#30) brackets to fuselage floor. Removed brackets, deburred and primed them with Zinc-Chromate primer.
Holes drilled, bolts torquesd, and torque seal placed on nuts.
Ruder peddal assembly in fuselage for the first time.
