Brief Description: Empennage Attachement #9 / Control Installation #1
Remounted VA-146 back on HS. Remounted HS to fuselage, and mounted elebators onto HS. Drilled bolt hole in elevators. Match drilled, deburred, and primed bellcrank. Also drilled, deburred, riveted, and primed F841 Elevator Pushrod.
Elevators installed on fuselage for the first time!
I fretted a lot over this hole, but everything turned out well!
