Brief Description: Riveted Left Elevator and Fixed Tabs
Did a little dimpling that I had left out on the skin and touched up the priming on the skeleton, then riveted the skeleton to the to the skin. Left the Trim spar unriveted so I can finish correcting the tabs. For the tabs, I cut off the messed up tabs with my Dremmel and then cut down the ribs from Practice Kit and sized them to fit the area where the tabs had been. Then measured carefully the rivet holes and drilled them in the skin to match the rib. Looks great and fits very well!
