Riveted Rear VS Spar IAW Van's Construction Manual. Had some problems trying to sqeeze two rivets on the bottom rudder hinge. Ended up using the back rivet plate, a bucking bar and a hammer as the back rivet set would not fit over the rivet. The results of this method were fantastic and they are probably the best looking rivets on the hole rear VS spar!!!
