Much more sucess today! Disasembled everything from yesterday, drilled out the bad rivet, and drilled the two missing holes in each HS405 Rib. Deburred the new holes, primed and reassembled everything. Riveted HS405 to the forward spar and riveted HS404 to HS405 and rear spar, Results were great. Had to use the rivet gun for all HS404 to HS405 to Front spar rivets as the squeezer just wouldnt fit! Off to se my Dad for Father's Day, but can finally start riveting the skins to the skeleton next session!
