Chad's Challenger II Site
Date:  4-29-2007
Number of Hours:  4.00
Brief Description:  Fill and test brake lines
I finished the brake installation. Big problem here! I didn’t anticipate the fact that squeezing one lever could force fluid into the reservoir of the other lever. The brakes work beautifully only if both levers are squeezed simultaneously. Fluid motion closes a check valve. May be forced into using a closed system (no reservoirs) like the levers Mike Harrison uses.
