Brief Description: Took Ailerons for paint, re-installed landing gear
I re-installed the gear leg cross cables and installed drag cables. I adjusted the cross cables without weight and will adjust the drag cables after re-installing the engine and with someone in the pilot seat, i.e. in taxi configuration. I also took the ailerons and wing struts to Murle's for paint.
