Chad's Challenger II Site
Date:  9-3-2006
Brief Description:  Antenna Ground Plane
I lined the underside of the front and middle gap covers with AL foil tape (2" wide). I cleaned the surface with isopropyl alcohol first which helped the tape to stick. Because the tape glue overlap insolates each strip from the next, I needed to tape down two longitudinal copper braded bare wires. I checked the continuity and this worked very well.
Front section
Front section
Center section
Center section
