Brief Description: Installed Front Control Stick PTT button
Finished installation of front stick PTT switch. I used a copper plumbing 3/4" end cap to install button. Worked well. Riveted it in with a 2/32 countersunk rivet and filed it to the curve. This way, if I pull up on the grip, it won't put tension on the wires.
