- Make sure the Cabin Frame is level and the tires are inflated to 20 PSI - Set wing dihedral at center chord and station 3951 to 85 mm - Set wing incident angle to 3˚
The hight adjustabe wing stands came in handy to set the wings to the above specification before drilling the wing bolts.
Please note: The wing attachment bolts cannot be set with the wing root top skin (Part Nr. 75W5-5) in place. Use nut plates for that part so you can take it off easely for wing mounting and dismounting later on.
