Cut out the top & bottom skin for the elevator horn doubler, fitted the elevator horn doubler support angle. Fitted, drilled & clecoed the elevator hinge.
All work was carried out in accordance with the Zenith Aircraft Company Construction Standards 2007, Zenith Aircraft Company Photo Assembly Guide 2008 and the Zenith Aircraft Company Plan Set Serial Number 65-7512.
