Gregs CH650B Web Site
Date:  10-7-2009
Number of Hours:  2.50
Manual Reference:  6-G-1
Brief Description:  Nose Gear Leg
Tonight I drilled and fitted the nose gear wheel fairing mounts to the nose gear forks and then drilled and fitted the nose gear forks to the nose leg.
All work was carried out in accordance with the Zenith Aircraft Company Construction Standards 2007, Zenith Aircraft Company Photo Assembly Guide 2008 and the Zenith Aircraft Company Plan Set Serial Number 65-7512.
Nose gear leg & nose gear
Nose gear forks
Nose gear forks
Nose gear forks
Nose gear forks
