Brief Description: Part 03 Nose gear lower bearing support
Tonight I set up, drilled and fitted the nose gear lower bearing support.
All work was carried out in accordance with the Zenith Aircraft Company Construction Standards 2007, Zenith Aircraft Company Photo Assembly Guide 2008 and the Zenith Aircraft Company Plan Set Serial Number 65-7512.
