Brief Description: Part 02 Pannel Gusset & Instrument Panel
This morning I fitted the instrument panel gusset's to the fuselage upper longerons and then after setting the correct width I drilled and clecoed the gusset's to the pannel.
All work was carried out in accordance with the Zenith Aircraft Company Construction Standards 2007, Zenith Aircraft Company Photo Assembly Guide 2008 and the Zenith Aircraft Company Plan Set Serial Number 65-7512.
