Brief Description: Part 01 Upper Longerons & Top Engine Mounts
Today I set up and braced the firewall at 77 degrees and then drilled and fitted the upper engine mounts to the firewall.
All work was carried out in accordance with the Zenith Aircraft Company Construction Standards 2007, Zenith Aircraft Company Photo Assembly Guide 2008 and the Zenith Aircraft Company Plan Set Serial Number 65-7512.
