Turned the elevator assembly over and checked alignment, drilled and clecoed the top skin. Fitted and drilled the elevator trim tab.
All work was carried out in accordance with the Zenith Aircraft Company Construction Standards 2007, Zenith Aircraft Company Photo Assembly Guide 2008 and the Zenith Aircraft Company Plan Set Serial Number 65-7512.
