LARRY'S WEB SITE
Date:  10-7-2013
Number of Hours:  10.00
Brief Description:  Windshield instalation
Drilled and de-burred the jury struts and installed with 3/32 bolts.Installed the windshield today, there was no information on this part so I had to be carefull not to make a mistake. Started by locating the side trim on the door pillar, pulled the window up to it and clamped it in place making sure it was straight. Then installed the fiberglass lower trim and clamped it into place. Making sure that the window didn't move, Drilled the holes in the side trim and the lower trim molding, installed the top tril, drilled the holes to 1/8 and left in cleco's. Took the wing off and turned the fuse around and installed the right wing.
