Got up early this morning to try to complete the right wing, completed the instalation of the trailing edge skins, cut out round insp'n holes, installed frame work for square insp'n holes, installed fuel tank, adjusted wing to meet the wing attachment points properly, had to add shims to spread the main spars so they would fit. Drilled the hole for the quick drain, Left bottom skin in cleco's for insp'n.
