Layed out spars on the table for the second time as I had to do a head gasket on Tylers car. Drew a center line down all the ribs, I found this usefull earlier and it should help to align the ribs on center as you can see the marker line through the 3/32 hole that was pre-drilled at Bush Caddy. Reilled and installed ribe to rear spar.
