Added 10 gal. of fuel, 5 gal. in each wing tank. had a couple of small leaks which I repaired. Fabricated a back plate for the fuel gauge to mark the gallons. added water and started the motor, let it run for a while, other than some small items to do, I'm done the build part so I won't be adding any more hours to the build log.
