Started out today by soldering the PTT button and installing them in the Y stick. Purchased the throttle cables from the Out Door Store today, Made a clevis pin and installed the cables, they work perfictly. Installed two throttle stops on both throttle levers, these are just 1/4" shaft stoppers from Princess Auto, they are simple and easy to adjust if needed. Painted the flap control lever and re-assembled it in the plane.
