LARRY'S WEB SITE
Date:  11-1-2013
Number of Hours:  4.00
Brief Description:  Flap handle
Made a base plate for the flaf handle assembly, used 1/4" aluminum and cut out a square where the handle protrudes through, drilled two holes in it and mounted it just fwd. of the cab base structure to give me enough room for the fuel lines to pass by. No need for a brace here as the 1/4" aluminum is strong.
Looks good, left room for fuel lines to pass by.
