Installed tube adapters into elevator tube and installed in torque tube, riveted using steel rivets, and put eye in place, drilled hole in and of stick and tightened everything in place. started on cargo door, traced out frame and cut out. placed door in opening and trimmed skin to fit. Placed shim under one side of the hinge as it is offset for a raised door skin, mine sits flat so I needed a shim to make up the space.
