Recieved the parts from Rotec today, exhaust, rad and oil cooler, oil tank, air filters, drip trays, exhaust heat muff that I installed along with the muffler, had to move the oil drain to the pusher position because it was hitting the heat muff, I'll have to check to se if this is ok. Fabricated a bracket to ho;d the oil cooler, drilled some holes in it to lighten it up.
