Replaced the engine mount bolts with the proper length ones, removed the mount braces so I could do the wiring easier. Replaced two bolts on the left wing flap hinge with longer ones, Removed and re-riveted the left wing outside trailing edge to try to lower it a little, now I need to adjust the aileron hinge to match.
